What is this?
Larry77
So I just traded in my '03 for an '07 V8 Limited and I found this connected to the passenger side headlight...what do you think it is? There is no markings or numbers on the small black box pictured....
P1060820.jpg~original
P1060819.jpg~original
P1060821.jpg~original
Don't Cut The Red Wire!!!
That is weird... just tapped into the headlights like that? I'd just take it off then. Never seen anything like that in all my electronic tinkering.
totally strange - is it at all possible to take the cover off of the black box?
it's hard to tell from the pic but is it connected in-line with the vehicle power for light?
could it be for an aftermarket alarm or something like that?
It's definitely the government.
But seriously, it almost strikes me as something like a wireless transmitter that is feeding power off of your headlight lines. Since you could move it around, maybe you could crack it or something? Otherwise, it doesn't look very important to the overall system functionality.
what else in the way of add-on's turns on/off with the headlights ? it's wireless signal to something else ( just a guess )
trailer, home alarm system, electric access gate...
davem said:
looks like a relay that keeps your low beams on with high beams, had one on my yukon.
Did you mean fogs? The low beams are already on when your highs are on.
Isn't that the turn signal? Is it one of those resistors for using LED bulbs? I'm talking about the thing that loads the wire enough to make the flasher work properly.
:cheers:
