What is your experience with wheel spacers?
1.25" ebay hubcentric wheel spacers since March. Zero vibration or issues mechanical issues. Really changed the look - stance of the old white gunner. Mild off-roading only. I can say, some very mild rubbing on the flairs up front with my smalish 2" lift over stock / up-sized 265-75-16 MT tires.
4 PC Toyota 1 25" Thick Hub Centric Wheel Spacers Tacoma Tundra 4 Runner Black | eBay
Front wheel studs on both my gunners are shorter than the rear. Need special lug nuts or longer wheel studs to be safe.
I've run mine since 2012 I think, without issue.
No shakes at 110 mph.
Spidertrax
Ditto.
Of course I used loctite (red). and I've also checked the torque on them a few times in the past couple years by dialing back the torque spec a ~15-20 ft-lbs and making sure they are on there to that no problem. As long as none of them budge, they shouldn't ever be a problem.
If they vibrate you probably installed them wrong or they are cheap junk, buy once/cry once. Have run them on many vehicles and never had problems, that being said if you don’t know how to operate a torque wrench or red locktite you should probably stay away from them.
Gonna be that guy and revive this instead of making a new one
What's up with 4.25" BS? I see the majority of people here run either stock 4.5" or 4.0" with some additional work, but what about in between?
Sorry if it's a dumb question, I know jack about wheel sizing.
usedautopartspro
