what size tires??
Whalergang66!
i have a 1998 4x4 limited. i just put a 2.5inch lift on and i want big mud tires. will 285/75/16 rub to much or what. i want as big as i can get with minimal rubbing and a lot of thread
No, those will be too big. For no rubbing, you'll need to stick around a 235 60 16. As for the thread, I'd go to a place like Michael's or Hobby Lobby, they always have a large selection, and different lengths.
thanks. i meant tread by the way haha. and 235 60 16 seems really small? i dunno im new at this so im asking questions before i screw anything up. i appreciate the help
265/75-16 will work with little to usually no rubbing.
Please search, there are tons of threads on this.
I run 285/75/16 on my 4runner with a 2.5 inch lift. The tires do rub a little on the uca. Not terrible but I would definitely recommend spacers if your going 285. I still need to buy some.
I am running 265 75 16 with an OME set up
Don't mind the rear that is a 6x12 enclosed trailer hook up with two zero turn mower two push mower and 3 weed eater and about 40 gals of fuel lol.
It will rub unless you hammer/cut your body. Suspension lifts don't change we're your bumpstops stop your tire from rubbing. Only cutting and trimming and or body lift will stop rubbing at full compression.
Mike Sargent
