WHORERUNNER
Looking at changing plugs on my 99 v6. What are you guys runnin?
On a related note, do you guys replace with OEM Toyota wires, or run something else?
What about the Denso iridium plugs?
That is what I was going to use when I do mine in the next few weeks.
Not necessary. Just get the NGK BKR5EKB-11's.
http://www.toyota-4runner.org/3rd-gen-t4rs/59008-how-installing-3rd-gen-spark-plugs.html#post487185
Must be dual-tipped:
Why must they be dual tipped?
What about the BKR5EKPB-11? The same plugs but platinum?
So yeah, to elaborate a little more, we have one coil for 2 plugs (3 coils total). The coil fires twice as often, once for compression cycle on one plug then again for compression cycle on the other plug. Therefore, your plugs get sparked twice as often as a normal single-tipped plug and will wear out twice as fast, except for the fact that our plugs have TWO TIPS! Voila!
If you want to put in a single-tip plug, go ahead... It will work fine... For half as long as it's supposed to...
No reason why it shouldn't work. Here's a post that justifies using platinum:
http://www.toyota-4runner.org/3rd-g...ota-4runner-ltd-3-4-v6-auto-2.html#post604717
Thanks much for the info.
Just ordered plugs, Wire set and front 02 sensor from Advance auto parts, found a 20% off coupon plus used my American Express card for an extra 3% back, so ended up getting it for about the same (less than $1) from what I could have gotten it on Amazon and I can just go pick it up.
Now just need to order Water Pump/Timing Belt kit and I am good to go.
Ohh okay. The ones we just pulled out of my brothers runner had 4
Which plugs/wires did you order
