what spark plugs you guys runnin? ngk or denso
They are both the same.
You are going to have a hard time finding the Denso. Denso do cost less. I know Sparkplugs.com has them but I'm not Going to pay $12 to ship a few plugs. I bought the NGK local for less.
As I'm sure you already know, only run the NGK or Denso dual electrode.
What about the Denso iridium plugs?
That is what I was going to use when I do mine in the next few weeks.
Also what is the best place to buy the plug wires?
On a related note, do you guys replace with OEM Toyota wires, or run something else?
The factory wires were Sumitomo's which are not available here as far as I know. Dealers sell Denso's. I use the NGK TE-66 wire set which are popular with members here and available at NAPA, Amazon and lots of other places. I got mine at sparkplugs.com.
i run denso plugs that i get from the dealership and i got ngk plug wires, i like the blue under the hood :thumb3:
i use ngk plugs and wires on mines.
the iridium are for those with superchargers on our motor because they are 2 step colder
and i remember they needed to be dual ground tips cause of the extra spark that happens.. something along those lines..
i mean why wouldnt we use the NGKs when they are made SPECIFIC for our 5vz motors and no other motor? :)
Why must they be dual tipped?
So yeah, to elaborate a little more, we have one coil for 2 plugs (3 coils total). The coil fires twice as often, once for compression cycle on one plug then again for compression cycle on the other plug. Therefore, your plugs get sparked twice as often as a normal single-tipped plug and will wear out twice as fast, except for the fact that our plugs have TWO TIPS! Voila!
If you want to put in a single-tip plug, go ahead... It will work fine... For half as long as it's supposed to...
What about the BKR5EKPB-11? The same plugs but platinum?
No reason why it shouldn't work. Here's a post that justifies using platinum:
http://www.toyota-4runner.org/3rd-g...ota-4runner-ltd-3-4-v6-auto-2.html#post604717
Ohh okay. The ones we just pulled out of my brothers runner had 4
Thanks much for the info.
Just ordered plugs, Wire set and front 02 sensor from Advance auto parts, found a 20% off coupon plus used my American Express card for an extra 3% back, so ended up getting it for about the same (less than $1) from what I could have gotten it on Amazon and I can just go pick it up.
Now just need to order Water Pump/Timing Belt kit and I am good to go.
Which plugs/wires did you order
