What the F$7k Just Happened?!?
Yeah that was my first thought. I figure if everyone on here around the NE is willing to keep any eye out, we should be able to find one.
The ones with the prices listed on car-part where listed at $1200. I would get a rebuild at that rate.
LittleCaesar, fighting with the GF never gets old. NOT! The Ram got hit in the back and has a bent frame.
Why does getting the pink milkshake ruin the transmission? I understand if you continue to drive without noticing the heat will ruin it, but what harm does leaving the mixture in there do? I have a pretty solid understanding of how an auto transmission works but I can't see how having an atf water mixture would do harm just sitting there.
North East, I thought you were in WV?
Yeah, listed there are probably expensive, but I think if you hit up some local yards you could get it for less. Or troll the classified on multiple forums for a part out. The tranny's go fast, but that's because they usually go cheap ($4-500 seems typical), plus then you have a better idea of the history. I have seen guys get a tranny for as low as $150.
I don't know specifically, but some components could soak up the water, corrode easily, short out , etc... Especially with it being in there for a week, I think that does alot of damage. Maybe if it were drained and flushed same day, you could minimize the damage, but I would think time exposed to water is bad, even if it isn't run.
I agree with little caesar too, I havn't been trolling as long as him, but I have read several guys that flushed after a milkshake, then a few months later reported the tranny failing completely or needing a full rebuild. One guy ended up rebuilding about 3 times because it kept going out, though I don't know that that was 100% due to the milkshake. If it was me, I'd troll for a cheap transmission, then swap it out. That may take some time though...
Here is what I would try:
Replace the radiator fully with a koyo ($150), drain out all the fluid you can fron trans and cooling systems. Pay the dealer $160 for a complete machine trans fluid flush. No need then to do 5+ flushes. They have a machine that will push it all out and replace the fluid.
I bought my '99 not knowing it had experienced the PM prior to my ownership. I think all they did was maybe drain and fill. That explains why the trans fluid never looked quite right, even after a few drain/fills of my own. And of course it explains why the trans failed shortly after I bought it. I think in most cases, it is inevitably going to need replacing.
I found a used trans from a Wisconsin truck not too far away (still had to be crated and shipped freight) for about $600, and another $550 or so to have it installed. So far, so good. It's been 2 years now. It only had 78K miles, compared to the 140K or so that was on the dead one.
Best of luck, tbst! And oh yeah - don't run that truck until you have all the gunk flushed out of the block, and a new radiator in there with fresh coolant!
It's not so much the water that does the damage, it's the antifreeze soaking into the clutches. It makes them slick, so they slip.
Wish me luck boys. DS disconnected. 313 mi.
5d06513f.jpg~original
Good to hear the engine is still ticking. Maybe do the drain and flush and use the meantime to track down a used transmission? Let yourself be choosy about getting a good one?
I didn't have a PM, but I replaced my transmission under a false diagnosis. Very stupid long story! With that said, I bought my used transmission from a totaled 4Runner from LKQ. They had a bunch from 400.00 to 1200.00. I think the 2001 and up transmissions are more rare and more expensive, so good luck there.
It probably wouldn't be cost effective for you, but I have a transmission Ive been holding onto for the possibility of mine going out, sitting in my garage. I dont know what the freight would be on it, but you are welcome to it if you end up needing one.
Finally dropped it off in PA. Even when it was broken, it the Runner was still useful. To winch a broken Jeep onto a car dolly. Imagine that...!
469ec1d1.jpg~original
997de0bb.jpg~original
be94b71a.jpg~original
I am moving to my buddies old house in PA. Left there is said jeep and he now lives in CT. The cost of the uhaul rental was the same to drop it off in Scranton or in CT so I said I would pull it up there since I had it anyway. Of course it wouldn't start. But luckily I had a snatch block and a winch.
I will respond to the above posts once I am off my phone
If anyone sees a uses tranny out there PM me, if I can replace it for ~$500 I will be happy to be back on the road.
PBR, I am going back to PA on Saturday. Need to fix my civic so it will pass inspection and work on 4Runner. Then I have to be on training for two weeks in Pittsburgh. So I need one car that runs.
After 600 mi of towing, I am out!
Good luck there tbst!
That just sucks concerning the Ram. If you could find another one for sale, it isn't a bad truck to own.
There is always Car-Part.com--Used Auto Parts Market for the local junkyards.
Thanks LC!
Who's truck is that you used to pull it with?
My best friend (Dale) dads truck. He is the dad you know who is everyone's dad and willing to help whenever. His mom is a tax accountant and does my taxes free, refusing payment. (He is not pictured that is another friend who is going to drive the truck back to OH.)
Chevy 2500 HD. Towed so well. I had to stop myself from speeding when towing the 4Runner. Downside? 10 mpg.
