what to use to remove leftover glue from window deflectors
Brian32
had to remove all of my window deflectors after 10 years of use...all of them started falling apart.. what cleaning product would you rec on getting the rest of the glue off??? I've tried rubbing achohol and water and vinegar...no luck
I agree with the Goo-gone, i also use WD-40 because i have it on hand more often, it works real good to.
Acrysol. not sure where to purchase it retail anymore, been awhile since I've bought any.. but any body shop can tell you where to get it.
Goo Gone or wd40 will do the trick. Put a good amount of either on a wadded up paper towel and hold it on the glue for a min or 2 to let it soak. Then use a plastic scraping tool to get it off. Just be patient and gentle with it and it will come off.
