techjockey
During an oil change, a local dealer indicated my 4Runner had 3mm remaining on both front and rear disk brakes. Since this is < 25% remaining brake liner, their recommendation was to replace the brakes reasonably soon. A month later I took the vehicle to a different dealership where we would be near for the day and asked them to replace the brakes front and rear. We left the vehicle there presuming they would be done with the new brakes in the afternoon. Instead we received a call that the brakes were at 4mm in front and 5mm on the rears. This represents 35% and 50% remaining and therefore the brakes were not needed on either axel - though probably soon on the fronts. The second dealer walked way from the repair stating it was not needed. How weird is that?
What would you do with respect to the original dealer? This is the same dealer that wanted me to replace the front and rear differential fluid at 75K and then when I decided not to do this unneed service on my 2006 limited, wrote "customer declined 75 service" in our electronic dealer service log.
What would you do? What should be reasonable? I'm thinking the intent or result was that I would be buying new brakes sooner with the original dealer none the wiser.
The original dealer wants to measure the brakes with me present so they can get to the bottom of this. If the brakes check out at 4 & 5mm - what should they offer?
Yes - I have paper service documents that indicate the conflicting measurements.
I feel like I've caught them red handed. Simple mistake or fraud?
