whats a tow capacity of a 1997 4runner?
4agze
well every track day me and my brother tow our toys to the track, san diego to willow springs is quit far i just want to know whats the tow capacity of the 4runner. the car we pull is only 1,854lbs
HPIM0569.jpg~original
July01-1.jpg~original
The V6 models are rated at 5000 lbs. The I-4 models are rated at 3500 lbs.
It appears you have a Limited, which only came with a V6. So 5000 lbs. is your 'Runners tow rating.
There are a couple thing to be concerned about. First is the tounge weight, the 4Runner allows 500 pounds. This is the weight exhurted on the htich while sitting. If the weight is over 500 pounds, the 4Runner will sag. Second, the weight is over 1,854 pounds. With gas it other items in the cars, it should could reach 2,000 pounds, still well under your limit. The trailer weighs something, I am guessing 1,000 to 1,200 pounds. So my guess is 3,200 pounds. With that kind of weight, it would be helpful to have a weight distrubtion hitch. It will help stop swaying. Third, brakes, you will need brakes on the trailer, it does take awhile to set these things up. Fourth, strain on the transmission and engine. I would recommend a transmission cooler. Also, drive with the ECT button on and the overdrive off. Instead of getting a oil cooler for the engine, I decided to use synthetic oil and keep a eye on the temp. dial.
Also, driving slower is one of the best things to do along with frequent stops. It looks like you have it already hooked up so you have probably addressed these 4 concerns.....
thanks guys, now i know that im ok to tow not just my track car but many more mid to small car.
tow cap
hey im new here but to let you know Toyota had a rear suspension update in 2000 or so because towing boats and trailers were bottoming the rear susp. out I worked at Toyota at the parts dept at that time and had it done immediately. they put in heavier springs and shorter axle bumpers, made a real diff. the rest of the truck is all stock besides the 31x10.5 tires I put on. has 290000 miles on
