What's everyone getting milage wise??
Something is clearly not quite up to snuff with mine.
I have only filled it up once so far and that was 100% stop & go city driving for the whole tank and I only got around 13MPG.
2002 Sport Edition, 157xxx miles, 3.4l 4X4, 3" lift 255/75R17 tires.
According to what I see here I should be getting at minimum 16mpg city.
I average 19 with a mix of city/hwy driving, mostly hwy. Straight hwy I get 19-21 pretty regular. More city driving gets closer to 16-17.
Stock 98 SR5 4x4 with 205k miles.
Nope. If all you do is stop and go city, you will probably get 12-14. I get 12 when all I do is drive in town. Be happy if you get it up to 16 city. Honestly, driving style has a ton to do with efficiency around town. Get a SGII and watch how you drive. I bumped mine up 3mpg just by driving different one tank. Got 15mpg around town.
I still can't believe anyone gets over 19 in a 3rd gen. People that say they average 20 or whatever, they must drive with an efficient style.
FWIW, my last several tanks have been averaging about 15.5. That includes a bunch of interstate.
My 4Runner is completely stock and I use Shell Gas exclusively. Tried V-Power a couple times just for the heck of it and the amazing valve cleaning.
City (Summer): 16 - 17
City (Winter): 13 - 14
Highway: 22 - 23 at 60 MPH Cruise
My wife drives the 'runner mostly city - grocery shopping, kid taxi. Average to date is 18.5mpg with the 265/75's on (and factored in the math).
My light went on today at 314 miles - my Ultra Gauge says I can go another 100 miles on it, but I won't take the chance. I have been averaging over 20mpg over my last 5 tanks.
My dad(who owned my runner before me) just gave me the info on his best trip on highway the whole time. Just worked it out(and yes my math is correct this time, lol) he got 24 and a bit MPG cursing at about 115 kilometers an hour. About 71.5 MPH. And it was through foothills, so not flat all the time.
I seem to be getting bait better millage than my dad was and I'm Babying this tank so I'll see what i can get.
SR5, 4x4, 285's and a 3'' lift, front tube bumper and a winch, no re-gearing, no supercharger. i get on average at 70-75 18-19mpg, and city 14-16 depending on how heavy my foot is. before my lift and tires and bumper i was seeing around 21-22 on the hwy.
This I 100% believe. The 60mph part is crucial. I bet I could get over 20 cruising at 55-60. But man, going 70-75 on the interstate with my setup, I only get 17.
THIS IS CRAZY. 314 miles on one tank? no way. im lucky to get 225-250 per tank. and thats if i milk it after the gas light has BEEN on.
ultraguage sounds like a pretty slick tool.
Off road bumpers, roof rack, 33" tires. 4.10 gears I get about 12-14 city and about 15-16 hwy. Need to regear or a supercharger gas is killing me:redbrick:
Well, I just picked up my 4Runner this past saturday and ran thru my first tank of gas. I filled up when I picked up the truck, drove about 180 miles on the highway to get home and drove anther 100 miles since then. I went 280 miles on that tankful before I decided to fill back up again. Did the math and I got 18.93 mpg for the maiden voyage. Not exactly what I had expected, but I did run 80+mph on the highway portion of the run, so I'm sure that at 70mph it will get 20mpg.
gasgauge.jpg~original
I just got mine a month ago and have been getting 16.5-17.5 mixed city/highway. Not too bad, but amazing compared to my 2nd gen. I need to do the plugs, wires, air filter, fuel pump and O2 sensor soon to help out.
I'm getting right around 18.5 as an average. The most I've gone on one tank was 322 miles, don't recall how much I filled up with after that but I know the tank was pretty dry.
This is all with new plugs, wires, seafoam, clean filter, and easy driving (usually have cruise set to 64 which is actually about 67 with my 265/75's, I think). I've noticed that tire pressure has a lot to do with what I'm getting and even how much the truck downshifts on hills. I have mine at about 32 psi and could probably go higher but that experiment will wait til' I get my ranchos on!
I've said it before in other threads but it's worth saying again:
You have to calibrate your odometer before you can calculate your true MPG.
Most odometers/speedos are off by a little but but adding bigger tires increases the error.
Think about it: Your odometer doesn't "know" how many miles you're going, it only knows how many times your driveshaft is turning. If you have bigger tires you will go further with fewer revolutions of the driveshaft, so the odometer will "think" you've only gone, say, 100 miles, but you've actually gone 105.
Best way to calibrate, IMO, is with a GPS. Most GPS units have a tripmeter on them. Set the GPS tripmeter to zero, then set the 4runner's factory tripmeter to zero. Drive around (the longer the better.) When it's done you will know how much of an error your odometer has.
Then, when you fill the tank and calculate mileage, you will have to multiply the miles by the conversion factor. Say your conversion factor is .032 (that is, it underreports miles driven by 3.2%). So when you fill the tank, you take the number of miles shown and multiply it by 1.032 to get actual miles driven. Divide that number by the number of gallons put in and you will have the true mileage.
As for my 4runner, I started using a web site called Fuelly.com to record my MPG. So far it has been consistently around 18 - 19 mpg average, which is right where it should be. I've gotten as high as 22 on long stretches of straight, flat road.
My Fuelly.com "badge" is below, showing my MPG:
and this is my DD Mazda's badge:
Which explains why I drive the Mazda whenever I can!
My last tank (filled up last night) was 21.3 mpg with 80-85% freeway. Normal city driving and such I get in the 17 range.
My 4Runner has 240k on the clock.
Stock 99 SR5 with 5 sp manual, 127K mi, Michelin 265-16s. I always seem to get 20mpg with up to 10% ethanol reg unleaded. Running at 70mph 60%, 35-55 for the rest. Bullet proof vehicle.
New to me truck. First full tank of gas I've calculated 16.1 on 50/50 mix of driving and a bit of A/C use. Going to hit 94 here today... blech. Haven't done any tune up at all yet nor calibrated for speedo errors.
Stock '99 w/ stock 16" tires.
Yes, close to 400 miles to the tank before I run out. I am completely stock - even down to the Michelin MTX or whatever the hell the truck came with - the PO put the same tires it came with when they changed tires. I also never go above 2500 RPM and my driving is about %80 highway. I also try to never go above 70mph since I have too many points and don't need anymore speeding tickets.
According to my UG I avg 24.6MPG doing 58MPH so I try to stay close to that.
http://www.fuelly.com/dashboard/
2001ATL
