What's the current consensus on the best 199mm caliper for the TBU?
4flyer
Member
I am about to do the Tundra brake upgrade on my '01. While I plan on running all OEM parts, I cannot afford OEM calipers so I am going aftermarket. There are so many options out there. What is the current consensus on the best aftermarket 199mm tundra caliper?
If you can’t afford oem calipers, is a tbu really the most important thing your 4runner needs???
At the moment, yes. Everything else is taken care of and the brake fade is driving me nuts. Perhaps I need to save up a bit longer. $900 for brake parts seem crazy to me!
$900 is crazy, especially since most calipers you'll find are just remanufactured OEM ones with new seals and pistons.
I recommend getting the PowerStop calipers off Rockauto.com. They are good quality, last and are reman'd OEM calipers. I think they come in Silver or Red. I went with Red, duh.
I got Napa reman's. Mainly because they were painted black and have a warranty. As far as I can tell the quality looks good.
Haven't had them installed yet.
Most of the aftermarket calipers are simply remanufactured OEM calipers. I went with the powder coated Cardone calipers from rockauto, they're pretty cheap especially if you get lucky like I did and they accept the 4Runner calipers as the core return.
Which calipers did you get? I'm looking to do the same. They have quite a few of those Cardone calipers. Those just as good as the Powerstop or other brands? Thanks.
Found tundra calipers from junkyard for $40 a piece. Rebuilt them and painted them red. Write ups are online. Alot easier than I expected.
NAPA eclipse calipers are Cardone calipers. They are powdercoated black and are usually pretty good and have a decent warranty.
patnewton
