What's the factory roof rack good for?
Buba1
I see most members on here swapping out their factory roof racks for these slim sleek aftermarket ones. I have the factory TRD Pro rack and planning to use it for a kayak or two and would like to get a roof top tent. Are the factory racks useless or can I throw on there something like kayaks without other attachments to it? I know for the roof top tent I would most likely need an aftermarket one...just trying to understand the full function of the factory one before I think about going aftermarket.
Weight is your limiting factor with anything on the OEM side presumably. I use 4 OEM crossbars for a roof basket which is adequate for my additional camping items. Had a canoe up there few times. Never any issue. Considered the Aftermarket cross bars for their tie down characteristics and accessories however. Might go that route eventually.
The new racks areally fairly beefy.. You can carry kayaks with out any issues. for a roof top tent good cross bars work with factory rails.
I also have a TRD Pro roof rack and want to keep it.
I've been trying to look for examples of using the TRD Pro roof rack with rotopax fuel packs but couldn't find any images online.
Do anyone know or have pictures of mounting rotopax fuel cans with a TRD Pro OEM roof rack?
We use the OEM rails and Thule AeroBlades to haul our 15 foot, 80 pound canoe. It's extremely solid IMO and we've never had an issue.
Any pictures of any of you guys using the oem roof racks for various applications? Just want to see some ideas.
Edited: Sorry OP, I should have read your post a bit better... I have the non-pro OEM rack.
Here you go:
The factory TRD Pro rack that has the two side rails and one rear rail looks like it would be difficult to put a kayak or roof top tent. I personally think the regular non-Pro rack is more utilitarian.
You can move the crossbars to the tip position and have a flat plane for tying down a kayak
Good for 10 gal fuel, 12 x12 ezup awning, 2 traction boards and a shovel.
Since upgraded to a frontrunner....sold my trd for 400 bones.
The weight capacity of your roof will not increase because you added a Prinsu. Most of these racks add weight while using stock mounting locations, the non-drill ones leave the front part essentially unsupported.
But they do give you more space and look hype on Instagram. Try using the stock rack until you need something else. There is no need to throw 40-50lbs of extruded aluminum on your roof just yet.
factory roof rack part of the solution
I carry two 17' canoes and the limitation of the factory rack is the narrow distance between the front and rear crossmembers. I need wider spacing.
On my Tundra, I use a 72" Yakima crossbar secured to the camper shell for the rear bar, using 2 control towers and Landing pad 6/7 secured to the camper shell permanently.
On the front, I use another 72" Yakima crossbar secured over the cab with Yakima Q towers and Q Clips specific to the vehicle.
On the 4Runner which I just bought yesterday, I will use Yakima Lowrider towers to attach the 72" crossbar to the factory side rails for the rear crossmember.
Over the front doors, I will use the Q towers and Q clips and a 72" bar. I bought the Q clips a few years ago anticipating I would get a 4runner. I'm not sure what number they are, they are not specific to the 4Runner but the word was the Q clips for Tacomas would work so I bought those.
Not great pics, but the Tundra is shown with even bigger canoes and the front bar over the cab. The Subaru shows the Lowriders hooking to the factory side rails. So on my 4Runner I will use those same parts, mix and match.
the rails themselves are fine, it's the OEM crossbars that most people replace because they have been known to bend and they have poor clearance above the roof
I have no issues with the OEM rails but I have 60" thule crossbars. I have my pelican boxes up there and keep some gear up there and out of the truck
I just bought a set of heavy-duty aftermarket cross bars so I could mount my box and Maxtrax to the OEM rails:
100% fine, solid and no problem at higher speeds.
AndiGarage
