Wheel Balancing in Triad
CPR
Junior Member
Anyone have a recommendation for a tire shop or dealer in the Triad area that can reliably balance tires on a 5th Gen? I’m on my third 4Runner/Tacoma and have yet to find a shop/dealer that knows what they’re doing. Decided on some KO2’s and TRD Pro wheels. The dealer I used claimed they had the proper adapter/cone, and they got close, but at 65mph+ the rear end randomly feels like Shakira is riding in the back and having convulsions. I am not expecting P Metric levels of comfort out of an AT tire, but this is a definite balance issue.
For 5th-gen 4Runner/Tacoma KO2s and TRD Pro wheel balancing, the Triad has reliable shops with expertise in trucks, bigger AT tires, and hub-centric balancing. Based on proximity, try these sites first:
Tire Discounters: Known for modern balancing devices, they excel with trucks using LT-rated tires. When visiting, request a road-force balance for KO2s to minimize the 65-75 mph shudder.
Discount Tire: Toyota trucks are usually safer here. Most stores know KO2s are balance-sensitive and carry hub adapters for 4Runner/Tacoma wheels.
Request:
  • Road force balance
  • Match‑mounting
  • Assess torque after 25–50 miles.
Best Tires—Greensboro NC New and Used Tire Shop: More budget-friendly, however some owners say they're adept at balancing if you provide your own specs and request a careful spin balance.
Total Car Care Tire Max: They carefully balance and orient trucks. They can identify tire, wheel, or driveline issues if your vibration comes from the rear.
Best Tires/Mobile new and used tires: Another affordable store. Not good for specialty wheels, but can do basic balance for a quick check.
Reed Tire inc: Established local shop with positive reviews. They possess experience with larger off-road tires and can efficiently balance them if they are within specifications.
Bruno's Tires: Small yet reputable shop. A good choice for someone who takes their time with each wheel.
Atlantic Tire & Service: High-quality equipment and consistency. One of the best options for road-force balance and identifying persistent vibrations.
Tips for KO2s and TRD Pro wheels:
  • KO2s often require road-force balancing, as a basic spin balance is often insufficient.
  • Survival race
  • For hub-centric TRD Pro wheels, the shop must utilize the Toyota-specific adapter.
  • Random or intermittent vibrations are usually due to balance or tire uniformity, not suspension.
  • Ask the shop to check radial runout—KO2 tires can be slightly off.
  • To check vibration follo
ws a specific tire, rotate front-to-rear after balancing.
