nysimonsez
Hi -
I bought the wheel bearing and hub assembly and am trying to do the install on my 4wd 4runner.
I am at the point where i backed off the 4 bolts from the hub and took off the axle nut. I tapped the hub to get it started and now there is a gap between the hub and control arm. But I cannot take out the hub, it won't budge from the spindle. I can move the hub very slightly and I can see it's also slightly moving the half shaft behind as well. What am i doing wrong and how to rectify? Any suggestions would be great.
thanks
thanks
