Wheel bearing assembly replacement help
Well I just did mine and was not bad at all.
Use a 3 jar puller and it is a snap.
Now I bought my assembly as the hub and then the bearing assemble was way cheaper.
But I should have bought the bolts because I had to take it to a shop and the guy cut the bolts out with a torch since it was faster and he did not have the right setup for his press.
I did the bearing/hub replacement last week. I hit the hub hard with a large hammer to loosen up the hub and then I use a pry bar and hammer to continue loosen the hub. Eventually the hub comes off. Takes some elbow grease.
That probably works in Cali, but would never work after several years of northeast de-icing chemicals.
alexaturner
