Wheel bearing bolt size needed
What size bolts hold the wheel bearing/hub assembly on? I'm talking about the 4 bolts that are sandwiched inbetween the hub and the bearing.
I bought the bearing and a hub and I'm going to press them together here ar work so i can swap it out tonight. Just need to make sure i have long enough bolts before i press it together
No it's still on the car she is driving. Trying to make this side easier than the other side that I did last week. It was hell getting the old bearing off the hub.
I just measured my old bolts (I save stuff like that...)
You need 34mm of thread past the bolt head.
Important to note that there is a 2mm thick washer under the bolt head, so effectively 32mm of available thread.
