thewaydown
Also, I’m so sorry if I hurt your feelings. Is this your first time on a message board?
I don't have feelings. I just don't approve of d-bongle attitudes either in life or on the internet.
You'll have to bear with Grave, he can be a little gruff at times but I beleive it's because since he pets every dog he most likely has been bitten a few times...But he means well!!
XREAS is a Toyota optional upgraded suspension/shock system that has the shocks interconnected so that when one wheel moves it affect the opposing shock in a fashion to give a more stabile ride, it's a great system but when it gets old and starts leak fluid and needs replacing it is very expensive, so most replace it with a regular shock setup.
If you ever need info on anything, google “4th gen 4runner _______________” and you will get all you could ever need.
Now that I have empowered you, google XREAS.
Hello all,
Did a little research in the forums and a little research myself and found that my passenger side wheel bearing is shot. The notorious vibrating that increases with speed, along with a slight pull to the right. The sound would go away when turning to the left, but would get worse when turning to the right. Jacked the front end up and checked for grinding noise/wobble on both sides. Driver side had no grinding or wobble what so ever. Passenger side had pretty significant wobble in every direction.
I know that its fairly simply to install these bearings since they come pressed in a hub assembly, ready to go. My question is, who has done this and what assembly did you use? Ideally, id get the assembly from bluepitbearings.com as I'm pretty sure its OE, but I'm not really in the position to be spending 280 bucks on it. I will, of course, if I have to, but I've noticed cheaper options. I just don't want to gamble and purchase a cheap-o and have some problem down the line.
A quick search on google for "4th gen 4runner wheel hub assembly" will give you some options. What do you think?
....Btw, whats a google? Do I have that on my laptop?
got mine in a week. I heard he was banned from tacoma world because he didn't want to pay to be a vendor.
Ordered from Jersey and it’s been over a week they still can’t provide a tracking number. Very bad customer service. Just an warning and heads up
I contacted him after a week went by and he said they were going to ship that day and tracking would be provided. 2 days later and 2 additional emails with no response smh. I’m just giving my experience and I I’m sure others have had good one but good luck with anyone who decides to order from him. Sorry for the negative first post but thought the community needed the info.
