Wheel spacers
gunny1001
I am about to install a ome 3" lift on a 99 limited what wheel spacers should I use. Thanks for the help. I'm sure there is a thread just to lazy to look..
that is not quite enough information.
What size tire are you wanting to run, what wheel, and how far do you want them to stick out. We have 1.5 inch spacers for $150 for a set of 4 but depending on your desired setup you may need less.
I just installed a 3" OME lift on my T4R and I am running 1.25" spacers. I think I am going to sell those and go with 1" instead.Things to consider are the size of tire you want to run and the backspacing of any aftermarket wheel if you choose to go that route. I see alot of members here keep the factory wheels.
Whatever you do, go with a hubcentric spacer. I've been keeping an eye out for 1" spacers myself, but it seems like 1.25" (e.g., spidertrax) are about it.
I am running 1.25" spidertrax up front, makes for a nice flush mount with 285/75/16's.. but nonetheless.. go with the minimum required when it comes to spacers IMO
chasebradshaw
