Wheelers T1 & T12 w/Bilsteins for V8
JeratBP
Member
Does anyone have this lift on their V8?
1. How do you like it?
2. What do you have the Bilsteins at - 0 or .85?
3. How much lift are you getting? The T1 says 1.75 + Bils @ .85" should be just above 2.5" right?
4. Did you need a 10mm spacer?
I want to be between 2-3" lift in front and close to level in rear.
http://www.toyota-4runner.org/4th-gen-t4rs/102272-4th-gen-suspension-options-faq.html
the T1 springs are the same eibachs that everyone else uses for the 120/150 platform toyotas. for a rear spring i would highly suggest you to get the metaltech rear springs. hands down the best rear spring ive run in mine (the icon overland springs are the same design with a little different spring rates and free length, both are amazing springs).
if you set the bilsteins at .85 it should be around 2.5-2.75 inches of lift. just be aware you will most likely need to get some aftermarket upper control arms for the front.
Ok so Bilstein's at 0" and maybe a 1/4" spacer to bring up the front a 1/2" more?
Im not interested in UCA's yet.
Bring back old post... I’m doing the same 5100 front and back with t1/t12 springs, but mine is a v6. If I set the front to 0” lift? the springs should give me 1.75” up front and 1.5” in the rear so should be about level right? or with a slight rake right?
charlesz
