Where is the Parking/Side Marker Light Fuse
gundrted+t4r
Hello
I'm looking at tinkering with my front parking/side marker lights. I would like to 'tap' both front parking lights (front/back would work too) at the fuse with an add-a-circuit adaptor.
For the life of me I can't find the fuse. I've found the turn/hazard fuse, but nothing around the parking lights.
I have found the below page and it seems to match the fuse boxes in my '17 TRDORP.
Toyota 4Runner Fifth Generation (N280) (from 2013) – fuse box diagram
Toyota 4Runner Fifth Generation (N280) (from 2013) ? fuse box diagram | Auto Genius
Toyota 4Runner Fifth Generation - fuse box - engine compartment
Fuse Ampere rating [A] Circuit
1 PTC HTR NO.3 30 PTC heater
2 DEF 30 Rear window defogger
3 DEICER 20 Windshield wiper de-icer
4 AIR PMP HTR 10 Air pump heater, AI combinationvalve
5 PTC HTR NO.2 30 PTC heater
6 SUB BATT 30 Trailer sub battery
7 PTC HTR NO.1 10 PTC heater
8 MIR HTR 10 Outside rear view mirror defoggers
9 TOWING TAIL 30 Trailer tail light
10 A/C COMP 10 Air conditioning system
11 STOP 10 Stop/tail lights
12 IG2 20 INJ, IGN, GAUGE fuses
13 HORN 10 Horn(s)
14 EFI 25 Multiport fuel injection system/sequential multiport fuel injectionsystem
15 A/F 20 A/F sensor
16 H-LP RH-HI 10 Right-hand headlight (high beam)
17 H-LP LH-HI 10 Left-hand headlight (high beam)
18 HTR 50 Air conditioning system
19 400W INV 80 Power outlets
20 ST 30 Starter system
21 H-LP HI 20 H-LP RH-HI, H-LP LH-HI fuses
22 ALT-S 7,5 Charging system
23 TURN&HAZ 15 Turn signal lights, emergency flashers
24 ETCS 10 Multiport fuel injection system/sequential multiport fuel injection system
25 PRG 30 Automatic running boards system
26 TOWING 30 Trailer stop/turn lights
27 SHORT PIN — No circuit
28 RAD NO.1 10 Audio system
29 AM2 7,5 Starter system
30 MAYDAY 7,5 Safety connect
31 AMP 30 Audio system
32 ABS NO.1 50 ABS, VSC
33 ABS NO.2 30 ABS, VSC
34 AIR PMP 50 Multiport fuel injection system/sequential multiport fuel injection system
35 DOME 10 Interior lights, vanity lights
36 ECU-B 10 Multiplex communication system, meter and gauge
37 H-LP RH-LO 10 Right-hand headlight (low beam)
38 H-LP LH-LO 10 Left-hand headlight (low beam)
39 INJ 10 Multiport fuel injection system/sequential multiport fuel injection system
40 EFI NO.2 7,5 Multiport fuel injection system/sequential multiport fuel injection system
41 ALT 140* HTR, 400W INV, A/C COMP, TOWING TAIL, SUB BATT, MIR HTR, DEF, DEICER,
STOP, PTC HTR NO.1, PTC HTR NO.2, PTC HTR NO.3, S/HTR FR, ACC, P/OUTLET,
IG1, ECU-IG NO.1, ECU-IG NO.2, WIP, WASHER, KDSS, 4WD, BKUP LP, TOWING
BKUP, DOOR P, DOOR RL, DOOR RR, DOOR D, P/SEAT FL, P/SEAT FR, DOOR, A/C, OBD, DOOR BACK, S/ROOF, PANEL, TAIL, FOG FR, D/L NO.2 fuses, AIR PMP HTR
42 SPARE 10 —
43 SPARE 15 —
44 SPARE 20 —
45 P/I-B 80 IG2, EFI, A/F, HORN fuses
46 SECURITY 10 Multiport fuel injection system/sequential multiport fuel injection system
47 SMART 7,5 Smart key system
48 STRG LOCK 20 Steering lock system
49 TOWING BRK 30 Trailer brake controller
*: Replace the fuse with one of the same ampere rating as the original
Toyota 4Runner Fifth Generation – fuse box – instrument panel
1 TAIL 10 Stop/tail lights
2 PANEL 7,5 Instrument panel lights
3 GAUGE 7,5 Meter and gauge
4 IGN 10 Multiport fuel injection system/sequential multiport fuel injection system, air bag system, smart key system
5 WASHER 20 Wiper and washer
6 WIP 30 Wiper and washer
7 S/ROOF 25 Electric moon roof
8 DOOR RR 25 Power windows
9 DOOR D 25 Power windows
10 DOOR BACK 30 Multiplex communication system
11 DOOR P 30 Power windows
12 P/SEAT FR 30 Front passenger’s power seat
13 S/HTR FR 20 Seat heater system
14 ECU-IG NO.2 10 Air conditioning system, multiport fuel injection system/sequential multiport fuel injection system
15 IG1 7,5 Turn signal lights, emergency flashers
16 ECU-IG NO.1 10 Vehicle stability control system, tire pressure warning system, steering sensor
17 DOOR 7,5 Power windows
18 DOOR RL 25 Power windows
19 AM1 7,5 Starter system
20 A/C 7,5 Air conditioning system
21 OBD 7,5 On-Board diagnosis
22 FOG FR 15 Fog lights
23 D/L NO.2 25 Multiplex communication system
24 P/SEAT FL 30 Front driver’s power seat
25 4WD 20 Four wheel drive system
26 KDSS 10 Kinetic dynamic suspension system
27 TOWING BKUP 10 Trailer back-up lights
28 BKUP LP 10 Back-up lights
29 ACC 7,5 Multiport fuel injection system/sequential multiport fuel injection system
30 P/OUTLET 15 Power outlets
Dude, its add a fuse.. so plug in the fuses.. tap the wire and plug in add a circuit and see if it works.. if not, move to another circuit. Pretty straight forward.its fused.. so i doubt you can cause any harm.
Can anyone confirm?
I am not a circuit or electrical guy but I don't see any harm in using an add a circuit. As long as you use two 10A fuses for your add a circuit; one to match the original circuit and a fuse for your new circuit of footwell lights. Just make sure your footwell lights aren't going to draw more than 10A. They shouldn't; unless you wire up A LOT of them haha. One for each footwell (driver and passenger), so two total, should be fine. Make sure you ground them.
Much appreciated sir. They are running off a 10A fuse.
