przm
I've been doing research on this all day today and I've come up empty handed. My issue is that when my sunroof is in the closed position it sits about 1/4 inch below where it is supposed to. In order to cut down on wind noise, every time I drive the car I have to tap the open button for half a second in order to get it into the actual fully closed position.
I HAVE tried reinitializing it, several times, with no luck.
I found this thread where user Pennywise is having the same issue, and resolves it using the TSB BO016-16 (Moonroof Stuck/Improper Operation). I followed the TSB, removed the map light assembly, the two side garnishes, the torx screws and the glass.
At this point I noticed that my sunroof and assembly looks vastly different than the way it is shown in the TSB. For one, my roof had 3 Torx screws on either side instead of 2 shown in the TSB.
The centering marks pictured are also nowhere to be found, I think I found them, but it's nowhere near what's pictured in the TSB.
It also seems my sunroof motor is nowhere to be found. I searched all over inside where the map light assembly goes for the gear assembly and motor but it is not there. This is the crucial step i'm at, I have to get it out in order to adjust the rails.
Here's mine compared to the picture in the TSB...
And from the reverse angle...
I found the tag for the sunroof (It's a Webasto Hollandia 700) so I figured that I might be able to find a service manual for the sunroof itself, but I had no luck.
I then remembered that I had a PDF copy of the 2006 4runner Repair Manual, so I found the section on the Sliding Roof Housing (06600210.pdf) and referenced the location of the motor compared to the location of the wind deflector. I found that same location on my truck and it seems like it should be exactly where the TSB describes it (right above the control switches).
I then found this thread mentioning referencing the Haynes manual, so I went out and bought the hanes manual. Unfortunately there is not a sunroof/moonroof section anywhere in there. I flipped through it page by page.
So... my question to you is: where is the sunroof motor so I can remove it and adjust my sunroof tracks? Did I miss something? :help:
