Where to get the low pressure power steering hose?
if you want to try some transmission fluid rated hose, 5/8 or 3/8 should work i forgot which one for the return line.
Thanks, looks like oreilys has "MasterPro 3/8 Inch P/S Return Hose - PS0308" - Confirmed this fit perfectly, just cut to size. Flushed out old fluid and bled, used Valvoline Max Life ATF. Toyota calls for Dextron II/III.
I found the Toyota p/n for the whole assembly which is a waste of money just to replace the rubber hose
Return Tube #2
44417-35011
44417-35010 (old p/n)
Philthyphilthy
