which coolant???
hairysrunner
Ok, LOL, which coolant should I use?? this will be for a 96 4cylinder with 260,000 miles. I guess what I'm asking is this, is the toyota bottle a for sure thing or can I get the equivalent at Advance Auto Parts? thanks in advance.
Zerex Asian Formula is nearly identical to Toyota Pink, and costs a lot less. NAPA has it, I don't know about Advance.
The only disadvantage is it is pre-diluted like the pink. I prefer 50% types. I use it anyway.
I would just use Toyota brand for piece of mind, the price difference is not that much. Also, make sure you are not mixing with another color that might already be in your system, flush the old stuff out first.
Maybe for you. (BTW: it's 'peace of mind':) ) I stay awake nights figuring out ways to avoid trips to the dealer when I can get the same thing for less elsewhere. I sleep just fine with ZAF in three Asian cars (two toyotas and a Hyundai.) I have researched the chemistry and I understand the issues.
ZAF is $13.49 at NAPA. Dealers get north of $20 for the pink. Plus I save on gas as NAPA is real close to me.
I use the oem and my truck never gets hot even in AZ summer driving in the mountains with A/C on.
Ya That's way North of $20.00 at my local Toyota dealership. Zerex Red is the same stuff.
I had mine completely flushed, and run Green. No problems.
(Almost) all anti-freeze is ethylene glycol based. They will all 'work' the same. No better, no worse in terms of anti-freeze and anti-boil--identical, and don't BS that OEM is any better at this than anything else. It's not. Ethylene glycol is ethylene glycol--period.
The issue is corrosion. Engineers have a menu of materials they can use in a cooling system; there is also a menu of technologies for the anti-corrosion additives in coolant. For instance, Asian engineers love phosphates and avoid materials that are attacked by them. European engineers use those things and hate phosphates. The Asians hate silicates and borates; europeans like them.
The modern green stuff is pretty much safe for all engines. It will not maintain its anti-corrosion characteristics as long as the fancy phosphated technologies in Toyota Red and Pink. They ARE different, contrary to many posts, but they both use phosphates.
As long as your green stuff is silicate and borate free, and it probably is if made in the last few years, you will probably will be fine. Just keep your change interval at 30k or less because it just can't approach the 50k or 100k performance claimed for Red or Pink. I use a Pink equivalent, Zerex Asian, and I run it 50k.
I wasn't joking when I said I had researched this stuff. Go play around on the coolant sub-forum at BITOG for a fascinating evening and an Excedrin headache.
:party:
/thread
I just went crosseyed.
Mike Sargent
