Which rims for 275/70/17 on stock 2022 Limited
anteek
Hi All,
Having trouble finding the rim width and offset is required for a stock 2022 Limited running KO2 275/70/17.
What rims are you looking at? Either other stock rim will work fine.
TRD OR rims are 17x7.5" and +25mm offset
TRD Pro wheels are 17x7 and +4 offset
I'm looking at this for sale ad https://www.toyota-4runner.org/3746001-post20461.html
The rims are 17X8.5 (6X5.5 | 6X139.7) with a -12 Offset.
I basically want to take my stock 2022 Limited and buy some KO2 tires, mount them to these rims, and put them on the truck and hope the offset fits and there's no rubbing and trimming required.
Thoughts?
Hi All,
Im running 265/70/17 K02s. I had a lot of drivers side and some minor passenger side rubbing, mostly on turning or backing up. I imagine 275s may be worse. I had to use heat gun to really reform the fender liner
Thoughts?
"No rubbing or trimming required" and going up in tire size really don't go together on 5th gens. You may rub, you may not. A lot depends on your alignment. I rub the body mount, removed the mud flap, cut the front bumper a little, and did the fender liner mod with only 265/70r17 KO2s on 17x8 TRD pro wheels and 1.25" wheel spacers, FWIW. I'm going up to 285s soon, but will remove the wheel spacers and even then may have to do a body mount chop or deal with the rubbing. I believe my offset is around -27 at the moment. Toyotas just rub.
Ambrose67
