Which setting is for highest lift on 5100's
lunarsnowstorm
Finally have a chance to install 5100's tomorrow. They've been sitting in the garage for weeks. Going to raise them to the highest setting and put toytec 2"super flex springs on back. One last silly question, Is the highest setting the groove on the bottom of the front shock or top groove of shock. Thanks don't feel like doing it twice.
The new springs are almost 3 inches longer, free length. I am not going with a diff drop, don't think it is necessary for this amount of lift.
If you are putting a 3" longer spring on with the 5100 in the front you will need to use the bottom setting I believe or you will go up more than 3". The shock itself has adjustments at .85, 1.75" and 2.5" assuming the stock spring is used. Someone else can check me if I'm wrong.
I'm using the stock springs up front. I believe he was asking me the difference in length of the super flex rear coils compared to the stock rear coils.
