While its out - Headliner edition
Rax_Dad
Member
Good morning!
I am in the process of swapping out my aftermarket roof rack for another one, a Sherpa this time (buy once, cry once guys) and replacing the roof rack bolts/retainers on the inside and cleaning up from the water leak from 1st said aftermarket rack... So I pulled the headliner out... When the rack goes in, I'm left wondering - While it's out, what else should I do? It's a 2007 Sport Edition.
1 - I have never had a sunroof issue, but admittedly - I don't use it a whole lot... Is there anything I should do to the mechanisms up there while the headliner is removed to keep it "issue free"? I live in the PNW so rain is a practically daily thing, but rust, isn't a huge issue.
2 - When removing the headliner, there was a bunch of wiring that was glued/silicone sealed to the headliner that had to be separated - I've seen some videos on removal and some discussion - But what are you doing when you put it back? Just stuffing it up there? Re-gluing it up there in sections?
3 - Again, not a lot on the topic of putting the headliner back in (at least in my searches) - On facebook groups the thing I see the most is "Removal was time consuming but not bad at all, re-installing it can be a challenge" - Anyone have any tips/tricks to making the re-install smoother?
Appreciate the help all - I have a couple of weeks probably for the new rack to arrive and get installed so while it's out - Figured why not make sure it's good to go for the next 16+ years.
When I get around to dropping the headliner I'm going to add sound/heat deadener. Amazing how much it can reduce interior temps. I added sound deadener EVERYWHERE in my old Tacoma and felt the HVAC system was able to work way more efficiently. Search Amazon for good cheap options
I did my 95 Bronco using Kilmat. That stuff worked great.
My $0.02
* 2nd on sound deadening / insulation
* Inspect all of the wires / Plastics for brittleness / Heat damage and replace any that concern you
* Run any wires you expect to need Ham/GMRS/CB radio/ lights for roof rack...
* Make the map lights up front come on with the doors. Toyota 4Runner Maplight Mod or search "map light mod" here on the 4th gen forum for other methods.
Boort
erinobr2000
