HurricanePaul
I think mine made that noise this morning. 2018 trdor with 3400 miles lol
Sent from my SM-N960U using Tapatalk
Sounds like the trans pump to me. Grab some spare vacuum hose and hold one end up to a trans cooler line and the other to your ear. Have someone rev the engine and see if it magnifies.
I replaced a trans for a similar noise after chasing pulleys just earlier this week.
I have the similar 2012 T4R SR5 V6 4.0L started doing it right after I booted the truck one morning, engine was not fully warmed up yet. (my guess is the oil pressure rushed higher when engine was cold, collapsed or clogged part of the oil filter when engine was booted and now was restricting the oil flow to the pump). It probably is your oil filter or the oil cooler.
The noise itself I am pretty sure it comes from the Oil Pump starving of oil ( because of cavitation), but the cause is "restriction" before the oil pump (oil filter failure or oil cooler/or line clogged). First swap the oil filter with a Wix or Toyota factory one and see if the "whine goes away" try one or more filter choices as well if one does not deliver results.
If that does not solve it, look at the oil cooler itself or a clogged oil line, replace that with a factory one. I am due for an oil change and will see if my whine noise is solved. Right now I am at 106k km's. Here is the same type of noise and problem from Nissan 4x4 blog: https://www.thenewx.org/forum/11-powertrain-driveline/21980-oil-filter-causing-engine-whine.html
Mine's still chugging along at 110k with no changes in the noise or issues. I just did a 700 mile loop in it last week through upstate NY and VT. I have learned to just ignore it at this point.
We just purchased a 2014 T4R with 87k miles, coming from a V8 4th Gen, same exact noise and it's been driving me crazy. You can hear it revving the engine sitting still and you can definitely here it while accelerating, seems to be loudest between 2500 and 4500 RPM.
Briefly asked the shop foreman at a local Toyota dealer and he thinks it's an idler pulley. I'm going to yank the belt of and see if it still makes noise. This thread has been very informative, thanks for posting!
