Boefeng are the little handhelds that are linked above. They have a huge following because they are feature rich HT's (Motorola coined the name Handi-Talkie for their walkie talkies) and are priced really low for what they are.
You being around wireless communication everyday you might have certain preferences in a radio. The HAM HT's are pretty small and light, probably a lot different than what you carry especially when it comes to reception and durability. They are limited to 5 watts and have small batteries so their range and long distance talk time is limited. At a lower power and HT to HT or through a near by repeater the battery will last much longer.
I have a Boefeng but it's the UV 3R, super small and limited to 2 or 3 watts. I use it for monitoring or simplex. It's got even fewer buttons than a 5R version but wasn't bad to program. One of the Boefeng gripes is programming. In my opinion they aren't bad at all as long as you understand a menu and what you're programming and why.
Here are the three handhelds I own.
Left is the uv 3r Boefeng. Middle is a Yaesu FT-60 and right is a retired Motorola MT2000. The Boefeng purchase was because it's small and like a toy yet still totally usable. It's small but doesn't have a long battery life or range, both because of the battery size. I use it on walks with the kids, simplex and with the crossband repeat on my 8800R in the 4Runner. This is a file internet photo. I have the updated one with 2 line screen and one dual band antenna.
The FT 60 is pretty much like a Boefeng 5R. It's a 5 watt max, dual band with keypad, memories, scan, etc. It retails for much more but is completely serviceable, weather resistant, heavy high quality case, higher end battery and is capable of using a high gain after market antenna. These are a couple of my antennas. As you can imagine the highest performing one is the long one. It's length can be a problem inside a vehicle or chest harness.
I bought the Motorola off eBay for my longer outdoor volunteer work. It's sealed, super tough, massive battery and has excellent receive and transmit. The overall duty of the radio is greater than that of the FT60 which is really nice. The MT2000 I bought is only a VHF. They have UHF and 800 and 900 mhz radios but my need was for VHF. As far as I could tell there aren't dual band which is ok.
Mine is older, like 10 years and still looks like new. It was probably in a holster all it's life but it's held up great. Newer radios have tons of features that aren't used in the amateur radio world. Plus they are super expensive so there isn't much benefit to buying one. New the MT2000 probably cost a department $1000 per radio, I got my set up for $110, programmed and delivered.
The radios need expensive licensed software that isn't available to the public or worth purchasing. It's not programmable in the field which can be a draw back. If I'm reliant on a radio I have more than one, my back up is the FT60 and can be pulled into service if need be. I've had my programs for years so I was set when it came to having a shop do the work for me. My model is a top screen with 3 banks of 16 channels, 48 total frequencies which is more than enough.
I use a chest harness when I'm using the radio somewhere else than on the trail. Most of that work is on a bicycle or mountain bike so i need the remote mic as the harness isn't really for a quick draw to talk. The longer antennas can make this setup cumbersome but I've found that the MT2000, which doesn't have aftermarket antennas (at least anything longer) has much better reception than the others with the stock antenna.
