Who has the most miles so far on a 5th Gen?
whaaat?! Really!?!? what am i doing wrong? :confused:
2014 SR5...63,000 on the clocks. i just had the dealer perform the 60K scheduled maint...
Its my dd, but i also own a pickup and a Kawi that i drive everyday from April to Oct...
I'm at a similar pace. Can I ask what you did for your 60k maintenance?
2010 SR5 93,000 miles
Just had to replace rotors since one warped and did pads too. I could have squeezed another 10,000 out of them probably. Those pins that are supposed to make pad changes easy were rusted on so bad...made the job a pain. Price you pay for having the stock pads last so damn long.
Otherwise flawless with oil changes and normal maintenance. Thing's a tank.
I didnt do anything special really. I just took it into my local dealer for them to perform the regular 60K scheduled maintenance, and i also had them rebalance the Cooper AT3s i had bought about 9 months earlier that the tire dealer didnt seem to balance right, or even close. turns out they had to remove them from each rim and remount them, plus center hub balance as necessary.
something like this
Toyota 4Runner Recommended Maintenance | Toyota Of Wallingford
Replace t-case fluid. Already did both diffs at 50k and will do them at 90k soon.
Otherwise just an oil change and tire rotation.
I tell them to lube the undercarriage, but so far only one dealer has ever done it so I'm on the dirty ass street doing it myself.
Bought my wife an SR5 4wd in September 2014. She had 122,000 this week before leaving on a trip to Missoula MT, from Fullerton, CA. So it should have about 125,000 on in when she gets back.
My 2010 Limited is currently at 143,520 miles. I've had 0 issues with the truck to date, slight of replacing a battery which is a normal consumable.
Just replaced the battery. Left the door open 10 minutes while under the truck and it would not turn over. Had to jump it. Had an oil change done at Walmart while on a vacation with it a year ago and they said the load test on the battery showed it low, like 450 CCA. We kept going on it because it was starting fine. But after this last episode, I immediately changed it and put in a 750 CCA rated battery.
i've got 64k on mine, bought with 51k in october 2014. 13k miles of fun for me so far.
my aunt who drives a 2010 2WD SR5 has 176k on her odometer. made me happy to know i could have a lot of miles left in my ride.
providing an update from above which was in August 2015.
Today my aunt's was totaled out at ~220k. She never had an issue with it and only performed routine maintenance.
Today mine is at 115k. No issues. Routine maintenance only, besides some offroading related replacements (CV boot torn, front drivers side diff seal leaking at which point i also replaced the needle bearing with the ECGS, etc.)
I hope i get as many miles as my aunt did out of hers!!! :hippie:
2013 ltd 37,000
Stays in the garage here in the boonies, the ATV gets more miles now than my armored rig. Go figure, such is the life here in the wilderness!
