Well, sorry this took so long to get done. I promised [MENTION=74569]SOcalTRAIL[/MENTION] I would post up pics of my 30" Engo LED light bar mounted to his bracket. The light took forever to get and the holidays have been busy.
I had to change my original plan of running a Rigid 30" E-series cradle bracket to mount this light since (of course) it is slightly longer than the Rigid 30". So, I went to Home Depot and purchased a 36"x2"x1/8" steel bar stock piece. I mounted the bar stock to SoCal's light bracket and used the feet mount the light bar came with to mount to the bar stock piece. I had to play with where I mounted the light because it was hitting the compressor lines if I mounted it too far back and it was contacting the grill if I mounted it too far forward.
So, I got the light mounted up and wired to an OTRATTW switch with Amber LED's. It matches the factory switch color perfectly and I am very happy with it. I have it wired to light up the upper light with the ignition and both lights when the switch is on.
I put the grill back on and I have a tad bit of contact with the grill and light, but nothing that prevented me from installing the grill. I am happy with the light output of this Chinese light bar, but you can definitely tell the difference in overall quality compared to Rigid.....obviously.
As luck would have it, when I installed the grill, the light bar sits directly behind my lovely 14" TOYOTA emblem, blocking a significant portion of the "Spot" LED's. The feet that came with it mount the light bar pretty high up. I called Rigid to inquire about their new stanless steel, 3-positon feet mounts that come on the new E-Series lights. They shipped me a set and I am waiting for them in the mail as we speak. I am hoping this will allow me to mount the light bar lower, making it sit under the TOYOTA emblem. This should also help with the grill contact since the top of the light bar is hitting the grill.
Enough blabbing, here are a few Antman-esque photos of the SoCal bracket, the light installed on the steel piece without the grill on, then everything buttoned up. These are teasers since I don't have any output shots yet or pics of the switch. I will post up more pics when I get the new Rigid feet mounts.
