Who knows the Lexus GX470 driveshaft part #?
wis99ski
After searching around for a while, and have not come across the part # for the driveshaft clunk issue. For those of you clunk free what was your fix and or new driveshaft part number? Thanks to TeryT as well.
Nah, not interested in that, been doing that for a while and the clunk comes back very quickly. Trying to keep this thread short and to the point here.
Maybe you need to use more lube, put several extra shots in there. That seemed to work for me. I pumped in the area of about 20 times on the driveshaft part. I haven't heard or felt it in about 5K miles. I will do this every oil change now.
Like I said been there done that! Not everyone's vehicle is the same and I have done the extra shots of grease etc. Does anyone know the gx470 driveshaft pt # that some 4runner owners are getting put in their vehicle besides TeryT who is gone for the wknd?
Thanks, thats a great start to what Im looking for. Being a little proactive should get this problem fixed like TeryT has done. Especially the situation Toyota is in now, when I talked to the service tech he was more genuinely nice then they usually are..hmmm
Its actually very easy to solve.
You don't even need to jack it up. Just get your SO to operate the handle on your grease-gun as you take the hose and put it on the zerks. I think there are 6 on the AWD models.
On the Ujoints, just a couple of hits should do it. Listen for them to "burp."
On the slip-joint of the shaft, I hit is 18 times. You don't want to put too much in, but it is reported than it takes quite a bit to do the job. Even after you lube this, it will take a few days of normal driving to not clunck. For me it was about a week. I think you could make it work quicker if you find places to drive where you cause the joint to work. Even diving on the breaks would be good as to raise the rear upward and stretching the joint. Maybe even a rough railroad track crossing would be good.
Good Luck......a whole lot cheaper than replacing parts.
I have found that lubing only lasts about a week before the clunk comes right back. And I'm using plenty of it trust me. I have come to the point where I don't even bother lubing anymore since it's just a waste of time to me.
I did read on here that installing a lift helps significantly for whatever reason.
Have to wonder if your clunking noise is being caused by something other than lack of lubrication? One week before the clunk comes back after lubrication seems way too short a period of time.
Personally, I have found that after I lube the drive shaft on my 4Runner the clunking stops for 3-5K miles. For me that is lubing once or twice a year at most.
That's an old driveshaft number. Lexus TSB DL002-07 calls for driveshaft 37110-60A40, and it also calls for installing a Rear Suspension Control Arm Kit, 04006-09160.
You'll have to get the parts at a Lexus dealer. Toyota doesn't let Toyota dealers order parts that only fit (or are supposed to fit) on Lexus-branded vehicles.
Well I drive my car much more than that.
