Why are Bilstein 4600 for 2wd more expensive then 4wd.
Hollywood1
2002 Limited v-6 2wd in need of front shocks. Stock springs with 1.5 lift spacers.
After a ton of back and forth on shocks, I’m opting for the Bilstein 4600.
It’s my GF’s 4runner which will most likely never see any harsh off-road. But after reading about the comfort between the KYB vs. Bilstein 4600 I think I’m opting for the more expensive Bilsteins. I’m not sure if I trust an aftermarket spring on a quick strut rather then the old factory front springs. Don’t have the funds for a 99’ tall spring and or 5100’s.
But looking at ShockSurplus.com, which is down the street from me, I’m noticing a difference in price between the
2wd 4600 24-188234, $178 Pair
Vs. 4wd 4600 24-187244, $161 Pair.
I haven’t really read any other budget viable options for shock swap that still give a decent ride. Everything I read about the KYB is that they are stiff and close to the same price range.
Any insight would be appreciated. ����
Probably just supply and demand. The front shocks will be the same dimensions, physically - just tuned for the lighter front end of the 2WD.
The 4600's are longer than the stock shocks (extended length) and may not easily fit with a spacer lift, FYI...
-Charlie
I ran (ok, my dad ran at the time) 4600's for about 80k miles, maybe more. They are a perfectly fine shock... OEM will be most comfortable - but also most expensive. I would expect KYB to be comfortable too - I'm surprised there are reports of them being stiff/uncomfortable.
Make sure you do the lower ball joints with OEM while you are in there. That's the #1 failure point on these rigs with age - especially if lifted.
-Charlie
TotalAutomotive is having a sale on Bilsteins, see what they can do for you. I just looked at this on his site.
Yeah I did both Ball joints on the Passenger side in December.
I used Moog ball joints, so hopefully they’ll hold ok, it’s got 180k miles now.
I’ll be swapping the lower Ball joint on the Driver side when I do the Shock swap.
Her passenger side shock is leaking, oil on the LCA and getting noisy over bumps.
I might just check the KYB’s to see if they are better on budget.
Those are good for 10-20k miles only - many examples of failures of Moog and other aftermarket lower ball joints on here. OEMs are good for at least 100k in normal street use (and often well over 200k - depending on how they are used).
-Charlie
-Charlie
Ok Thanks, I’ll have to double check exactly which I bought.
I generally use OEM or NAPA parts but I was on a tight budget and time frame to get it back on the road.
