Why cant i drive under water?
Remove your tires and make them out of metal. Then tap a fill valve into the sidewall of your metal "tires". When you get to the lake/pond/w.e. fill the wheels with water. BAM! Ballast tanks! You could even cut the sidewalls off your tires and attach them for better traction, plus it would be ****ty driving on the road with nothing but metal.
:D Go do it!
:D Go do it!
genius.
this guy is going places.
well problem solved..
it seems my helium filled continentals were causing the problem...
after the metal tire swap ill top off the TRD and hit the lake beds.
I think a flock of pelicans the size of new jersey would be suitable
hmm..
fuel wise, would fish to feed the pelicans be cheaper than Hindenburg fuel?
Seriously? This is the kind of weird, pointless thread that's gonna get some ridiculous amount of replies and go on way longer than it should.
Mount the rotary engine on the roof, use it to turn a helicopter rotor... put quad turbos on the 3.4, connect the driveshaft to a boat prop with gobs of thrust, plate steel on all the body openings, built in nitrous tanks for the interior so you can laugh your a$$ off all the way to the bottom of lake tahoe, then you can dive and fly your way straight to the middle east, execute precision aerial/submarine attacks on key targets, take all the oil, and come back a hero among both Mazda and Toyota owners.
Maybe then our 16mpg city/21 highway wont seem so bad.. because of you and your underwater 4Runner, gas will be 0.50/gallon again.
:worthless
I think you're lying about your sig cuz I don't see any bumpers on the roof. Those low end 5.70 fender flares are sweet though, gotta give you that. I need me some outriggers too for when I'm on the water!
its been brought to my attention that even if you used lead wheels the air space in a 4runner is prob to great and would cause you to rise...
so you got to go with a Tacoma or something with less airspace, you could stay submerged better!
