1994 2nd-gen Hilux Surf 3.0 turbodiesel 'Sasquatch'
pyemaster
Hi all
Like ExPo, I've been on this forum for a couple of years and figured I should really get around to posting the story (and a couple of pics) of my Hilux Surf, named Sasquatch.
In 2014 I wanted to find a good base and build up a tough overland vehicle capable of sustaining two people on long-distance surf-exploration trips with a high capability both on and off road. Of the many factors to consider in finding the right vehicle for the job, the utmost was of course reliability. For its low-end torque for off-road driving, cold-weather resistance, increased fuel economy and superior fording capability, it would have to be a diesel, and augmented by a turbo, so on-road driving wasn’t laboured and the vehicle was able to keep up with traffic.
I was also very keen to keep it as light as possible, helping to retain a good fuel economy and nimbleness off road - I didn’t need 8mm thick chassis armour and an exo-skeleton. During my search, I naturally kept coming back to the Land Cruiser’s little brother, the Hilux 4Runner, or Surf, as the Japanese exports are known. With a 1.8t kerb weight, the 2nd-gen Hilux Surf is almost half a tonne lighter than the similarly-aged 80-series Land Cruiser, and offers 5mpg better fuel economy, running the 4-cylinder 3-litre 1KZ turbodiesel (as opposed to the 6-cylinder 4.2-litre 1HZ naturally-aspirated diesel in the 80-series).
The Hilux’s engine and transmission is a proven drivetrain offered in Land Cruisers too, fitted in some 70-series (the successor to the iconic 40-series), Prados, and the latter 90-series Colorado models. There’s also the build quality – these transmissions have been known to be opened up at 200,000km with no metal shavings found on the magnets. The 2nd-gen Surf’s interior can comfortably become a camper, with occupants sleeping inside, as opposed external ground camping, or having to carry a heavy roof-top tent. Accessing your bed from the cab is of course totally weatherproof, better insulated, and allows for much increased security. After a few weeks of searching, I found the perfect base model: a black, imported 2nd-gen 1994 Hilux Surf SSR-X Limited, totally stock, kept in a car port and only used on the weekends. The second-highest spec level offered new, it was in damned near as-new condition and had clearly been cherished its whole life with a full service history. It arrived off a ship from Japan in 2002. Roll forward a dozen years and here I was, arriving with a one-way train ticket and £1,200 in my pocket.
It's been a long, fun build since then, including shakedown trips into the Picos de Europa mountains in Northern Spain (sleeping 5,200ft up above the snowline of one mountain where backcountry skiers were unloading below us the following morning), another European trip (covering 3,000km through 5 countries, including some excellent mountain forest tracks in both the Bavarian and Austrian Alps), and most recently another 4,000km trip through 3 countries, mainly on a surf mission to the far SW tip of continental Europe, including hundreds of kilometres of off-road driving through the Serra de Monchique in Southern Portugal, and some excellent coastal tracks and sand driving in some south and west coast wilderness areas. It also came to the rescue of a number of people in the worst blizzard conditions Britain has seen for decades last winter, working multiples nights in recoveries of immobilised vehicles, delivering health workers to emergencies, and in getting to people stuck in snow drifts in remote areas on the cusp of hypothermia!
Anyway, let's get down to business, here's a list of the work in the last 4 years:
- New head, head gasket, head bolts, water pump, cambelt, pulleys, tensioner, filters, belts, Aisin viscous hub, rad cap, full exhaust, hoses, re-cored radiator, 71 degree thermostat, TREs, front bads, discs and calipers, bearings, CV gaitors, rear universal joints, transmission solenoids, front drop links, rear ARB bushes and brackets, diff fluids, transfer box fluid and transmission fluid, 830CCA battery, bump stops
- Fully-sealed impact-resistant polyproylene Bravo snorkel (same design as a Safari)
- Auberins coolant sensor and gauge
- Aftermarket ATF cooler with separate line
- Fully waterproofed electrical connections underneath
- Full breather kits fitted for rear diff, front diff, transfer box and transmission (mounted high on firewall)
- 2" body lift
- 2" lifted heavy-duty Lesjofers rear springs
- 1.25" aluminium rear coil spacers
- 2" Pedders nitrogen gas shocks all round
- Pedders heavy duty steering damper
- 15" x 8" modular steel wheels (x5)
- 33" x 12.5" Toyo Open Country Mud Terrains (x5)
- Panhard bar cut and sleeved
- New OEM rear load sensing valve on custom lifted bracket
- New OEM front torsion bars, lifted 1"
- Rear braided steel brake hose
- Custom rear brake lines
- Aisin manually-locking freewheeling front hubs
- Rebalanced prop shaft
- Toe/camber/castor all laser aligned and adjusted
- Full Krown rust treatment on chassis, engine bay, driveline, suspension and body (on and in all panels up to the window line)
- Custom steel tubular front bumper
- Custom steel rear bumper with twin swing-arms, one for spare wheel, and the other for 60L of diesel in 3 lockable Jerry cans (bumper with rated rear recovery points for 4.75t shackles welded in-line with chassis rails)
- Custom aluminium roof rack, bolted to Thule roof bars, with galvanised mesh base
- Custom steel rock sliders
- 4crawler rated front recovery points, customised to accept the bigger pin for 4.75t shackles, mounted to chassis rails
- 2m x 2.5m awning
- Custom, low-profile, carpeted, full-length 3/4" hardwood marine ply drawset (on 48 skateboard bearings) for tools and expedition equipment, with 4 hinged side storage compartments
- Steel vehicle safe mounted and sealed through vehicle floor
- Waeco CDF-11 compressor fridge on a custom slide, wired to auxiliary battery
- 48" Hi-Lift jack, Hi-Lift winching kit, lift-mate attachment, 16ft of grade-80 recovery chain, 4.75t shackles, heavy duty tree-strap, 4m bridle strap, 8m tow strap and 10m extension tow strap, all lift-rated to 4t
- T-Max 12v compressor, with tyre repair kit, spare inner tube, valves and cores, and rapid tyre deflator
- Backup 12v compressor
- Longhandle shovel, mounted on rack
- 2 x fire extinguishers (one 900g BC in passenger footwell, one 1l E-series water-mist mounted on D-pillar)
- 2 x lifehammers mounted on front door cards
- 110Ah auxiliary marine battery (with 800+CCA) installed on a Durite split/charge relay
- 2 x sub fuseboards for all accessories, split independently for starter and auxiliary
- Twin air horns and compressor fitted
- T-1000 Thunderpole CB radio mounted on dash, along with twin battery voltmeters and Auberins coolant and EGT gauges
- 4ft Firestik top-loaded antenna for CB with heavy-duty spring base and custom aluminium base plate
- 5ft springer antenna for radio, with custom aluminium mounting bracket
- Griptaped sliders, bonnet and roofline above windscreen for roof rack access
- 2 x 9" Hella halogen spotlights mounted on front bar
- 2 x 12" LED light bars on roof
- 3 x 12v 20-amp accessory sockets installed inside rear D-pillar in the bed
- Fully armoured cables underneath
- 4" rotating 18W LED camp light on rear pole with optional yellow filter, custom hood, dimmer and speed-adjustable flash settings for breakdown warning
- Hidden kill switch in vehicle
- Uprated 4t bottle jack
- Sony Bluetooth stereo upgrade with uprated speakers all round and slimline 8" sub-woofer under passenger seat
- Dash holders for 8" tablet for maps, smartphone and USB-chargeable twin handheld radios for spotting
- 12v extra-quiet fan installed in rear for air circulation
- Mosquito-netted rear windows
- Twin self-inflating camp mats and British military Snugpak sleeping bags rated down to -12C
- Black-out 5% limo-tinted windows (on top of existing factory tint) on all windows from B-pillar back
- Pocketed side storage in the bed, including fully reflected cold-store in rear window alcove for food and cooking utensils/cutlery/equipment
- First aid kit mounted behind cargo net on opposite window alcove next to fire extinguisher, with matching stickers on outside locating their position in the vehicle
- Interior roof cargo netted for clothing storage, with drybag for dirty laundry (doubling as a washbag with detergent and water)
- Bed storage of cast iron camp oven, MSR Dragonfly stove and expedition maintenance kit, gas bottles, Stanley thermos, foldable SnowPeak chopping board, folding fire pit and grill (SnowPeak design), 12v shower, heavy duty jump leads and high-vis
- Large Maglite mounted on side of trans tunnel in front footwell opposite fire extinguisher
- High-level LED indicator repeaters mounted on rear spoiler with 3rd brake light
- Red LED nightlights fitted inside for reading and to detract bugs
- 20L interior water tank with tap
- Auxiliary 20L exterior water ex-military Jerry can on rack
- Locked and strengthened Plano military storage box on rack, with all spare parts and room for wetsuits
- Roof rack bag, containing 4 x recovery boards, 2 x Kentucky camp chairs, 2 x aluminium camp tables (one big, one small), tarp, bodyboards and fins
- Full emergency grab bag mounted on rear of drivers seat
- Trasharoo spare tyre rubbish sack
That's pretty much it, probably missed a few things. I designed the vehicle so almost all heavy weight was to be stored as low down as possible and between the axles, with lighter, bulkier stuff up top. With 60L of extra diesel in addition to the 65L standard tank, it now has a 1,000km range between fuel stations, and a cruising economy of 22-23mpg. Fully loaded with 2 people and kit it weighs 2.7t, with only a slight weight distribution to the rear.
Anyway, here’s a couple of pics from the recent Portugal trip:
Owen
Yep, i like! Looks like you put alot of work (and money :) ) in that truck.
Where in Portugal is this? Looks like a nice area for some light holliday offroading trip. Portugal is on our go-to list.
I noticed you don't have a rear license plate?
Thanks mate,
Mainly southern Portugal, in the Serra de Monchique and surrounding coastal areas on south and west coasts. There are plenty of extreme tracks around that area, and remote too, though without a fully roll-caged comp truck there was no way I was tackling the most mental ones!
The hardest tracks we did I didn't take the camera out for, I was too busy concentrating on not rolling the thing!
Yeah ripped my rear plate off in some undergrowth halfway up a mountain on the second day, on a track tight enough you'd have struggled to get a Land Cruiser through ;)
Also snapped off the rear swing arm holding my spare getting down to a beach after it had taken a pounding on some corrugations for most of the day. Luckily it was on the last day of the trip!
Owen
Made my day
great rig. Would really like to get ahold of that engine here in the states...
I have an '89 3.0 that is also on track to become a legit adventure rig.
I’m impressed. Someone actually talking openly about the 3.0 as an option for traveling away from pavement on “legit” adventures! There is a lot of disrespect shown for this engine, which is not totally justified in my opinion. It’s not perfect, but few engines are.
Owen; nice rig you’ve built. How easy is it to get away from other humans in Portugal or northern Spain? We hear a lot of talk about how there is very little true wilderness on the continent, but it seems like you found a few spots to get away from the masses.
Hi Redthies,
Yeah Europe isn't a huge continent, but make no mistake there are still large swathes you can escape from people. There are big mountains and forests, an incredibly long and diverse coastline, and having a well-kitted four wheel drive will obviously help you get to those places off the beaten track.
That said, as a continent it's nothing like what you get in Oz, the US or Africa. There just aren't huge areas of nothingness, even in the middle of the Spanish plains you still find the odd settlement. You can't disappear off the radar for months on end in Europe like you can in WA, but you do get ten times the culture and nine-tenths the enjoyment of exploring tracks, so I'll take it!
Owen
Perf!
We have all 'adventured' with far less as rigs go. Not saying I will not go 3.4 or diesel at some point but not going to hang out and build sand castles while waiting for a perfect rig when I own a legit, kick-ass runner. Having been properly maintained over its life, I'd not hesitate to take this thing to the end of the civilization and back. Besides, tires and other equipment choices are far more pressing in back country ventures. I can still see a diesel in the future. Always wanted to rebuild a lil one.
Hi Redthies,
Owen
Thanks for the insight Owen. My wife has EU citizenship, so we are thinking of maybe moving to either Spain, Portugal or Italy in the semi near future. Of course, we are also considering South America just to keep the family guessing. I’m casting a vote for Europe due to more political stability, and food/culture options. We currently live in Vancouver BC which was just ranked as the 2nd most expensive place on the planet to live. I’m looking forward to buying 5 hectares with a stone house and barn with maybe some olives or grapes for the cost of a studio flat here! Of course the property would require a 4x4 or three!
Perf!
I will enjoy the 3.0 until the day when it gacks, and if that happens in my lifetime, I’ll be doing the same... 3.4 or small diesel swap.
Yes that's exactly the way to go, my friend recently bought an acre of land in the central region of Portugal up on a hill about an hour from the coast, and it cost her €2,000.
Owen
Owen
WOW! Don’t spread that around too much or by the time I’m ready, it’ll cost €3,000!
Incredible rig!!:rockon:
currently working on turning my 98 3rd gen into something comparable. will definitely be referencing your thread for upgrade considerations :thumb3:
cheers!
goddesszilla
