rebelbowtie
There is no problem with tight turning, because of the Torsen center differential.
In a part-time 4WD system, when you put it in 4WD the front and rear driveshafts turn at the same speed. When you go around a corner, the rear wheels cut inside the path of the front wheels, so the rear wheels travel a shorter distance. As a result, the rear driveshaft needs to turn fewer revolutions than the front driveshaft. Since the front and rear driveshafts must turn at the same speed in a part-time 4WD system, it is hard to turn tightly on dry pavement (and potentially damaging to the drivetrain).
But the 4th gen 4Runners are not part-time 4WD. They are full-time 4WD. The center differential allows the front and rear driveshafts to turn at different speeds. Think about what a rear differential does -- it has an input shaft, two output shafts, and allows the two output shafts to turn at different speeds. The center diff does the same thing.
As a result of that center diff, there is no scrubbing when making a tight turn in a 4th Gen 4Runner, as long as the center diff is unlocked. If you lock the center diff, then the front and rear driveshafts turn at the same speed so it behaves like a part-time system.
As for "all the moving parts all the time," what moving parts are you worried about? So the front driveshaft, half-shafts, and front diff are turning. So what? Those aren't exactly parts that tend to wear out quickly. And if you need to accelerate quickly in the rain, like entering a fast road from a parking lot, the truck just goes -- you don't have to worry about spinning your rear wheels as you might in RWD. You never have to ask yourself "should I put it in 4WD or not" -- it already is in 4WD.
Exactly, once you go AWD you never go back.
