kobusLifeRemotely
Guys, gals, and fans I need advice.
22500 miles ago I replaced my inner tie rod on my 97 4Runner SR5 because a dealership said it was failing and worn. After I had it replaced there was still a little clunk and play when placing my hands on the tire at the 9 and 3 o'clock positions and moving the tire back and forth rapidly.
I had Firestone tell me that the bushings on the rack and pinion looked warn but not to worry about it. So I didn’t.
Two days ago I felt a clunk when breaking, then I felt it again while just driving on a freeway, today I felt it accelerating and breaking. Also when I moved the steering wheel back and forth there was the same clunk.
So I jacked the truck up, and tested the left front, the same side I had the tie rod replaced. There is a lot more play on the wheel than I remember.
So my question is twofold.
Advice is greatly appreciated.
- 1. What can cause the same tie rod to fail in 22500 miles?
- 2.Should I have it replaced again or be looking for the culprit and then replacing everything?
