Wierd Electrical Issue after Battery Service
Strongmad
I have a 2003 Runner, 4.7L. Yesterday it would not start. I looked under the hood to find that the negative terminal of the battery was not connected. I reconnected it and tightened the cable. (Long story short, this was a result of a terribad battery installation by my local Firestone garage. I have been going to this garage for seven years without issue. Needless to say, I sent a nasty email to the CEO, and CFO. I found their email address through google and copied the consumerist.com. Maybe I will get published!)
To the point, my wife says that the rear windshield wiper will not function and that the driver side window one-touch roll-down function no longer works. Has anyone had a similar problem? And if so, what was the solution? My next step is going to the stealership, which I desperately hope to avoid.
Solutions?? Many thanks in advance!!
Re-initialize the "auto-windows" including the sunroof. The rear wiper will work again after you do it.
- Cycle the window full travel, both directions, while holding the button steadily for the full travel, that's it...
:cheers:
All those things are completely normal after replacing the battery or disconnecting it for an extended period of time.
Thundro
