Will an FJ Cruiser sway bar fit on my 2004 4Runner?
Like the title says, need to know if an FJ sway bar will fit on my 04 4Runner. Anyone?
This question may not matter but front or rear? I think I have both fronts laying around in my garage but my rear sway bar came off in two pieces, although I should be able to check those as well, later today. Both my brother and I removed ours and he replaced his rear with a stiffer sway bar.
They look like they are identical, the rear FJ bar is smaller in diameter though, easier flexing I suppose.
Inv4drZm you are a god. Thank you for doing that for me.
I guess I should have clarified in my OP that it was for the front. I literally lost my swaybar and have an inspection coming up.
Required equipment? I know down here it's not required, merely the ability to pass a swerve/cone test which I'm 99% sure I can without f/r sways
Getting an out of province inspection done. They like to see all the suspension components there. Plus, my rig isn't exactly inspection friendly, so anything helps.
Wow, that's an intensive inspection. In Texas they honk the horn, check the lights and read the OBD2 and send you on your way for like 30 dollars. They couldn't care less what suspension you have as long as it rolls.
Bunkstaff
