Will Freedom Offroad UCAs from a Tacoma fit my 4th gen
PJP71
Member
Found a good deal. Supposedly the oem ucas swap right over, so wondering if these will too. Saw that the FOR Tacoma UCAs part# FO-T701FU vs FO-T702FU for 4th gen, FJ, GX470. Thought I saw somewhere that it is a different ball joint? Curious what the difference is and if they will still work?
The 4runners have a larger UBJ and tapered shaft, which is believe is due to large GVWR of the 4th gens. I recently Installed Tacoma SPC arms with 4runner UBJs I had to get separately, and there is certainly a visual chunkiness to the 4runner taper shaft vs the Tacoma taper shaft. Unfortunately I don't have a pic showing it well
^^ This is 100% correct. The 4runners have a larger upper balljoint.
H.Sikina
