Will these wheels fit 231's??
Jamiesparkman
So I have the Callahan brake kit setting in my garage, brake lines come in tomorrow but I still have the split-5 4runner wheels. Looking for a cheap option that does not include spacers. Found these on the local cl.
How much does a set usually go for at a junkyard? That may also be an option..
Correct. Those would not work without grinding. You should be able to find a set of the 5 star on CL pretty reasonable - I know they fit:
Anyone knows if this would clear a 231caliper? 16x8 procomp 7031 got a 4.5 backspace with a 0 offset I'm also running 1.5 wheel spacers.
Theres nothing wrong with spacers, as long as you don't mind the extra track width. When I had the stock split spokes, I used spacers to clear my 231mm calipers and have had no regrets
If you go with new wheels, be sure not to forget the cost of mounting and balancing your tires on those wheels.
so was there ever an actual yes or no to this question? I'm gonna be doing the 231 TBU soon and I'm looking for OEM rims. Found a set of these at a local dealer for cheap. Was told they came off a '15 Tacoma.
Anyone?
Bueller? Bueller?
