Will these wheels fit?
gusred
I may be purchasing a set of wheels and if anyone can help me i would appreciate it.. The wheels are 18x9, 6-139.7 bolt circle, 77.8 center bore, and a 20mm offset. . Thank you in advance..
Just a suggestion, but I think you'll get more accurate responses if you specify the exact vehicle you want to put the rims on. 4Runners are not all the same with regard to rim availablity. For example the Sport Edition model has bigger rotors than the SR5, so rims that might fit the SR5 won't necessarily also fit the SE.
Sorry.. I have a 2004 4runner SR5 with stock 17 inch wheels.. And the new wheels i want are 18inch . So i doubt rotor size would be an issue. Hope this will help me get an answer.. Thanks..
Me thinks it won't fit. My door sticker says: Use rim 16x7JJ with 265/70/16 tires. My 4R came with the TRD 17x7.5JJ rim with 265/65/17 tires.
What size/brand tires will you run?
Are you stock height?
no, they won't fit. the center bore isn't big enough. all late model toyota trucks (except 08+ tundra) use a 105mm center bore.
Thanks..
Thanks for the responses guys.. I currently have these wheels and tires on... And i want to downsize wheels for gas millage,,, but do not know what to get ..
Yes
gusred are your running boards painted silver?? talking about the top part... and what will you be doing with those 20s??
My running boards are painted.. I just painted my roof rack as well... Love the look. As for my wheels... They will be for sale soon.. Pm if interested..
