Will V8 sway bars fit a V6?
Roody
Member
Tried searching but to no avail. Quick question here, hopefully straightforward.
Will OEM sway bars off a 2003 2WD V8 fit a 2005 V6 4WD?
I plan on adding aftermarket quick-disconnects if that helps at all.
Thanks!
im wondering the something but the opposite, will the ride will be softer if i have a V6 sway bar in my V8 when i hit the bumps..
Sway bar diameter seemed to vary greatly between models as discussed in the polyurethane sway bar bushing thread but all should fit all as long as you have the correct diameter bushings for whatever sway bar you're trying to install. Now will there be a noticeable difference between the smallest and the largest diameter sway bar? Probably not much. Difference between no sway bar and any sway bar? Yes. So if you're trying to change the ride by sway bar then unless it's free you're probably wasting your time but if you don't have them and you want some antisway it's worth it.
I have the sways I was asking about on the way.
So I need the V8 bushings, how about quick-disconnect end links? Anyone know about these?
MaximussK
