Wimpy Horns
Toy4Rnner
Guys, I replaced my oem horns on my 2k 4r but ran into a problem. I replaced them with a WOLO (B320-2t) with the two prongs connect on it. the Oem horns each had a male/female connect.... when i spliced the wire for the drivers side horn, there were two wires. I was thinking it was for each prong on the WOLO so I connected it. the WOLO direction said to use a wire that was provided and ground it to the body of the car in which i did. I did the same thing on the passenger side horn but that only had one wire that fed in to the oem horn..which was weird. so after all the install, only the driver's side replacement horn is working now......HELP!!!!! thanks
Talyn
