Wind
grousehunter 61
I have a wind sound in the rear of my Toyota, sounds like a window is open, I also have the dust spoiler and wonder if that could be the problem. Anybody remove theirs and did it make any difference.
Check for a gap between the tailgate and the body when its closed. Check from the inside. Mine was a ton quieter after fixing that.
I bought some spray silicone to wipe on the rubber, hope it gives some new flex to the seals. My Camaro is a T-top and I use that on it, it's an 83 and no leaks ( yet ) I will let you know how that works.
If the tailgate is bent outward like I stated above, there will be a gap since there isn't a seal in that spot.
Thanks Keaton, I don't see any sag or gaps, not to say its not there. So I will try the easy way first and if that doesn't work we will try something different.
