Window channel seal
Eisenfaust
So, I'm trying to find a place to buy one which supports shipping to Europe. I found something at JChWitney's (even don't know if it is the right stuff) but there is some problem with shipping abroad.
Any other suggestions?
thanks.
You might try one of the discounting dealers(like Olathe Toyota, no affiliation). They call them "window runners". We just bought one for the right rear door which ran about $95 for a factory part. Just a warning, it's a pain to install. In the back doors, you need to pull a lot of stuff.
regards
yes weather strip is a term used for sealing the vehicle from the elements.
look for window weather strip inner and outer to seal the glass on the doors and hatch.
look for door weather strip to seal the actual door itself.
window runner/trim seal
I found something at 1988 TOYOTA 4RUNNER Parts - ToyotaPartSales.com
Since English is not my native language, does Weatherstrip refers to window channel seal as well?
Also on e-bay: 1989-1995 Toyota 4Runner & Pickup truck new door weatherstrip seals, pair | eBay
I suppose 89-95 refers to 2nd gen (although I run 1st gen dated 1989) but can those fit on 1st gen?
The first one you listed , is the outer trim piece at the bottom edge of the glass. The second, is the seal for the door itself. If you want what the window slides up and down in, is called a "window runner" by toyota. At least this is what the parts guy in Olathe told me. I know them as a weather strip, by what ever. The nice piece about dealing with a discount dealer, you'll get the right part for your VIN.
regards
Many thanks guys.
Although I managed to find several dealers with that item, non of them ships outside US.
Do you know somebody that ships abroad (Europe)?
Rear window inner seal
My 1st gen, '88 is missing the rear window inner and outer seal which sandwich the glass when the window rolls up out of the tailgate. I've discovered that the outer seal is easily sourced. The trouble is that I discovered the inner seal is discontinued. Because of this, every tailgate assembly that I've found has been stripped of this part.
This is the biggest issue I'm having with this vehicle because exhaust vents directly in through the rear window missing seals when any of the other windows are opened. You can imagine how annoying this is during summer.
If anyone could please help me with:
- What is the part number of the inner seal
- Is there an aftermarket solution which replaces this?
I apologize if this post has ended up in the wrong thread, I'm just getting acquainted with the forums.
Thanks!
seltzernator
