Window Master switch not activating front passenger
Bigcee
Member
Sup,
My window master switch isn't working on the front passenger window. All other windows work. The passenger window works on its own door switch.
I tried resetting turning the key to the run position, going to the passenger side door and running it down and holding for 2 secs then running it back up and holding for 2 secs.
Anything else to try?
Once in a great while, the passenger side will window will respond to the master switch briefly.
Sup,
My right rear window was doing this. It started working randomly after I must have accidentally completed the normalisation procedure when using the controls on that door rather than the master.
Have you tried the good old disconnect battery and start all over again procedure?!
Lol, I guess I haven't tried that yet. I know I should also unplug and replug in both switches and see how the connectors look.
