Window motor years that interchange
dirk22
I need to replace the driver and passenger window motors I was wondering if other year trucks or runners interchange.
If you are going to a yard just take yours with you and compare, but the Camry of the same year had them. 88-91 I think. That being said, they sell them new with a warranty and they are not as bad as I would have thought.
Now all that being said, if your driver and passenger needs to be replaced, I have to ask if you have checked the door/window relay? Have you jumped both window regulators to your battery to ensure that they really are bad? I'd hate to see you waste money.
I'm with other on this, check the wiring. Harness breaks at the flex points( ie where the door opens) are quite common, or are more common then one would think. I have a good used passenger motor(RR) in our garage, but I won't be back down there until Tues. I can email you the part # if yours turn out bad. Best of luck with it.
regards
