windows without key in
3bears
Senior Member
so this evening I noticed that the windows will go up or down without the key even in the car. the key was in the house, yet I can make any of the door windows go up or down, did not try the tail gate or sunroof
ideas ?
Window circut could be jumped? Or bad body ecu not timing out? Bad door switch?
My widows can be operated right after shutting off the engine for about a minuite and while the drivers door hasn't been opened yet.
After about a minuite, or if I open the drivers door all power is cut to the windows.
Has the window relay is stuck closed?
When I installed power windows into my 92 Prizm, I wired it through a fuse directly from the battery, so it can be operated without the key in the ignition. On a hot summer day I open the driver's door, press all 4 buttons to roll windows down before I get into 140 Fahrenheit interior!
