Wiring Diagram
Does anyone have the wiring diagram for the speakers that run to the back of the second gen T4R? I'm trying to find where the old wires are and I'm having a hard time tracing them from the back of the car. Thanks in advance!
I have a factory wiring manual for 1990. They indicate the left side wires as Yellow and Black. The right side are White and Red. It also indicates some circuits there for the power harness for the antenna (L-Y, B-R, P-L, L-Y). They originally installed the rear speakers in the plastic side panels in the rear of the truck. You might pull them and start a trace.
regards
Yeah I've been pulling the back apart and to my surprise it would seem as if each side has it's own amp that it is connected too. there are at least 5 wires that run out of each and how they end up turning into 2 wires that run into the back of the stereo I have no clue
[MENTION=128525]theking11863[/MENTION] you would be correct that there was an amp for each of the rear speakers. I took mine out when they burnt up and tried tracing wires forever to find the correct ones with no luck. I ended up just running new wires from the pigtail from the stereo to the speakers directly.
Not a big deal, just use the solid colored wires for the new speakers. When they wired these trucks, it was done in their own way. They really were not meant to have exotic additives like a radio, power windows and a/c, per say.
regards
After doing some searching around and looking at the wires I did end up finding the wires I needed and reconnected them. Not the best sound but its a start. Thanks guys
DJNutshell
