WMW Full Length Rack for 4th Gen T4R's!!
I'll be getting one of these for sure!
Will lighting tabs be included or will there be an option; front, rear and maybe alley light too?
Good question. All racks will have a flat shelf welded in the bottom of the front section to make mounting various lights or accessories possible. Additionally, I can weld on light tabs anywhere you like for $5 each.
Found some GREAT photos of [MENTION=63060]rickashay[/MENTION] 's rig. His is obviously a 3rd gen but he opted for the full length floor option and has this great photo showing it. He also made his own wind fairing from plexiglass, a simple project that works like a dream. If you have time, look up his wheeling pics thread, his photography work is amazing.
rickashay3_zpse1deae18.jpg~original
rickashay6_zpsabe4ca30.jpg~original
BlackWorks, the brackets are about as tight as they can comfortably be. As they sit, the center of the rack is about 3/8-7/16" from the roof. This is to allow for a little room for flex which will happen when heavier loads get bouncing on a rough road or trail. However, if you want one tucked in even tighter I'm game. Also, the mesh is welded in to eliminate any noise from it bouncing.
Darn, I thought as much. I had hoped the left to right curvature of the roof was far flatter that it looked. Oh well, still a great product! Now all I need is money! LoL
I can't wait to see this. Like some others said, I wanted a Gobi but I refuse to pay that much. Sadly my work internet blocks all the pictures. I'll have to check this out when I get home.
Does it narrow towards the front?
Maybe the pictures are playing tricks on my eyes, but your 3rd gen rack seems to be the same width front to back but this one seems to narrow a bit towards the front. It may be how the feet are mounted that are throwing me off.
Nope, its the same width front to back, its actually the mounting channel on the 4th gen roof that WIDENS towards the front, which is what makes these a little tricky and gave me ulcers setting up the jig. heres a finished photo of deedst4r's rack, you can see the mounts are obviously different and have the angles of the roof built into them.
IMAG0467_zps1674da71.jpg~original
Wow, that looks great! It looks like there are tie down points on the mounting feet. Few questions:
1. Are the mounting feet tie downs standard?
2. Could you do two evenly spaced front braces (instead of the four) between the top and bottom rails without losing structural integrity?
3. Would you consider/have you done adjustable cross rails for mounting things such as ski racks, etc?
Thanks!
Thanks!
I am also curious about removing the two upward supports on the front to better accommodate lighting.
Thanks!
The tie down points can be left off if you hate them, I just thought it made sense to make use of that realestate. I can customize these pretty much any way you like, within reason, so a different frontal design is no big deal, it just has to have "some" support up there. I can make adjustable crossbars but the hardware I'm limited to isn't the "prettiest", its strong and functional though. I'll see if I can find a pic.
Here we go, little hard to see, 40 each, and they're 1" to accept popular accessories.
IMAG0420_zpsf1cee94c.jpg~original
Looks absolute great, nice work.
charlesz
